Blue Hawaii Special Edition
  • Replies 1.5k
  • Views 419k
  • luvdunhill
    luvdunhill
That psu is just one of many BH variants that I've drawn up over the years.  500V input caps and 450V output caps.
You can get it through with some care (that's what she said.... ;D) but a drill does help.  Just make sure to deburr...
even the 1486?
What kind of press, Joachim? Avoiding the expense of PEEKs seems worthwhile (apart from the torque discussion).
Edited by GeorgeP
This one looked really good... until I saw the price. Will try to find something similar under $100.
even the 1486?
The 1486 is partially insulated so you just need the ceramic insulator for them. Better yet, use the KSA1156 where you can.
Now you know why we keep increasing the clearance of the ground plane around the traces.  :)  The KGSSHV power supply was he biggest headache as there we have roughly 700V of raw DC floating around.
My longest bit of troubleshooting was last summer, two months to find a phantom noise in one of my BHSE's.  Came and went but was finally tracked down to the TV antenna causing a ground loop.   :mikey2:
i thought it was an arc in the pic, but it was a whisker that i missed. had that whisker not been current limited by a 1M resistor, it would have most likely blown apart
The inside of that blue Hawaii looks amazing,never seen the lid off the Psu though,be interesting to look at that too,Think I would leave the covers off,make it more exciting tip toeing around it plugging the headphones in and out,joke
Are cats doing your soldering now Justin?  Good, and apparently lucky, find!
that's what Justin gets for using quality made in usa circuit boards.
time to use the Chinese crap.
You wouldn't say that if you just had the day I had trying to track down the short(s) in a board.
I feel even luckier ;)
i've had one that i could never find even after knowing exactly which trace was shorted, and looking at it under a microscope. it had to be internal. kevin's idea of blasting it with high current did the trick
i also had a board where I had paid for the flying probe testing, and a short was found - i could see where they used a blade to remove the short. However what they didn't do is test it a 2nd time, because there was actually a 2nd short on the same trace. I didn't consider that possibility so that one took me a while to figure out  :mikey2:
Edited by justin
  • 9 months later...
I was moving my setup around and unplugged all the cables without paying attention to how they were plugged in.  Is there a certain direction that the umbilical cord needs to be plugged in?  or can someone send me a copy of the instruction manual? Don't know where my manual is right now.
On the Nate bhse, it only works one way. There is a male and female end. If it is the same on both ends I'm not sure how it could be directional.
On the Justin BHSE, there is also a male and female end.  I am concerned about different rotation of the cord when you plug it in (it plugs in with a 3 by 3 grid). Perhaps I should look closer, maybe there are some grooves so that it can only plug in one way.
