DIY cable gallery
  • Replies 606
  • Views 264.5k
  • Harvested an old Cardas Headphone cable to make a balanced cable for the HD800. Neutrik 4-pin XLR connectors. The HD800 connectors are from Parts Connecxion and a royal PITA to work with.
  • luvdunhill
    luvdunhill
    Even scarier
  • I made some cotton sleeved speaker cables - going to get them hooked up to my horns which I moved my rack over to the side and as such needed two different length cables… couldn’t find any coconu
Good grief those are expensive.
depends who you know I guess :) I thought a certain someone was going to do a little groupy buy?
There are plenty of pure silver connectors out there, Goertz, Eichmann, WBT and Bocchino all spring to mind. Stealth Audio also has solid silver connectors, RCA, XLR and even power connectors.
depends on what you alloy it with.
Tritanium from the Enterprise.
Finally got pissed off enough at the stock cable being annoying due to cable memory, so I recabled my K1000:
I gotta learn to take better pictures than this if I'm ever gonna put a website back up though. :palm:
I've also seen posts lately about the K1000 being difficult to recable / easy to damage, which leaves me a bit confused after having gone through the process myself. I guess it's difficult if you've never really recabled headphones before? I found the whole process fairly straightforward, especially since I didn't have to make any new strain reliefs or anything like on some other phones. :confused:
Good job there sir! I don't suppose that you took photos of the process?
My understanding of why it's difficult is because it's tricky to reassemble the parts of the cages/housing after they've come apart.
Thanks! No, I didn't take photos of the process, but it probably wouldn't be too big of a deal to take one side back apart for photos tomorrow. The grilles are annoying sometimes, but I wouldn't call them tricky to reassemble so long as you know how it's supposed to go together.
I thought it was difficult because the drivers are particularly prone to damage due to inadequate heatsinking during the soldering process. I presume they still sound okay?
I'd be pretty concerned over what kind of ape is doing the soldering if they manage to cause damage from heat. The way it works is a little weird to describe without pictures, but I'll give it a shot anyways. The voice coil solders to a pair of metal posts on the back side of the enclosure, these posts do a couple bends to bring them closer together then come out the front side of the enclosure. The PCB has two slots on one side with solder pads around it, so it slides in place against the rods then it's soldered together on that side. The cable has to be soldered to the PCB before it goes in like this, as it routes behind the PCB and is soldered on the back in a different spot.
Getting the PCB out to replace the cable is ridiculously easy... remove the two screws then hold the soldering iron across both solder joints for the posts (they're real close) while pulling the PCB away. Only takes a couple seconds to heat it and remove it with a proper soldering iron. Same thing going back in... might have to reflow the solder on the board if it's blocking the little slots for the posts, then just set it back into place and resolder the posts to it.
I blame it on ape's doing the soldering as by the same reasoning the Stax drivers should never even be touched with a soldering iron. With the Lambda drivers you are soldering directly to the brass rings which clamp the diaphragm in place or directly to the stator plates which are held in place by small plastic bits which could easily melt.
You braid really well. How do you do that? Mine always come out uneven.
Adding one more to the eye candy archive.
Thanks for the kind words guys.
Stretch, I see what you did right there. ;)
Greg, I find the key to a uniform braid is as simple as having a solid anchor point. That lets you have a consistent tension on the wires and keep the same relative angle as you progress.
I find armpit hair a great place to practice this technique.
Great work Nate!
