DIY cable gallery
  • Replies 606
  • Views 269.1k
  • Harvested an old Cardas Headphone cable to make a balanced cable for the HD800. Neutrik 4-pin XLR connectors. The HD800 connectors are from Parts Connecxion and a royal PITA to work with.
  • luvdunhill
    luvdunhill
    Even scarier
  • I made some cotton sleeved speaker cables - going to get them hooked up to my horns which I moved my rack over to the side and as such needed two different length cables… couldn’t find any coconu
Added a balanced termination to a stock Senn cable
If anyone has some cheap extra grills I would be interested...
Ran across a spare pair of 580 grills that are yours if you want them.
  • 8 months later...
Quick question: can you take out the LEMO and XLR connectors from the Sennheiser HD800 balanced cable and reuse them for another cable or are they glued?
  • 6 months later...
figured I'd post this here, no other appropriate place.
had some old ribbon nordost rca cables that I wanted to use for xlr duty. ended up using copper braid for ground because it conforms to the ribbon shape well:
seems to work without issue so I'm content. I'm considering similarly covering up the ugly kinks in some goertz cables:
is there anything you can do to keep the braid from oxidizing?
Edited by nopants
  • 8 months later...
Does anyone know someone that might be willing to "balance" a set of J-cable A-T headphones? Either keep it a J and use a TRRS cable (need the verify it isn't this way already), or convert it to a Y. Just looking to farm out the work :)
Anyone have a short stereo mini phono to stereo mini phono lying around? I'd like to buy it for my jobsite rig.
  • 2 months later...
Apparently HD800 cables are not bunny proof :( why couldn't the bunny have worked on the power cables not a few feet from the headphones?
Just eat it.
But not too soon, unless it'll taste oxygen free copper and teflon.
  • 8 months later...
Truly lovely.  Is it for a soundbar?
No, it goes to this:
You can see it exiting the cabinet here
Overhead
I particularly like the heatshrink sleeving over the braid. That is really tough to do without melting the braid.
