January 8, 201412 yr comment_617555 Added a balanced termination to a stock Senn cableuploadfromtaptalk1373203797618.jpg If anyone has some cheap extra grills I would be interested... Ran across a spare pair of 580 grills that are yours if you want them. Report
October 6, 201411 yr comment_655342 Quick question: can you take out the LEMO and XLR connectors from the Sennheiser HD800 balanced cable and reuse them for another cable or are they glued? Report
April 25, 201511 yr comment_682600 figured I'd post this here, no other appropriate place. had some old ribbon nordost rca cables that I wanted to use for xlr duty. ended up using copper braid for ground because it conforms to the ribbon shape well: seems to work without issue so I'm content. I'm considering similarly covering up the ugly kinks in some goertz cables: is there anything you can do to keep the braid from oxidizing? Edited April 25, 201511 yr by nopants Report
December 30, 201510 yr comment_715260 Does anyone know someone that might be willing to "balance" a set of J-cable A-T headphones? Either keep it a J and use a TRRS cable (need the verify it isn't this way already), or convert it to a Y. Just looking to farm out the work Report
February 4, 201610 yr comment_719384 Anyone have a short stereo mini phono to stereo mini phono lying around? I'd like to buy it for my jobsite rig. Report
February 13, 201610 yr Author comment_720183 You would want two short mini plugs wouldn't you. Report
May 6, 201610 yr comment_729326 Apparently HD800 cables are not bunny proof why couldn't the bunny have worked on the power cables not a few feet from the headphones? Report
May 7, 201610 yr comment_729401 Just eat it. But not too soon, unless it'll taste oxygen free copper and teflon. Report
January 13, 20179 yr comment_751937 Truly lovely. Is it for a soundbar?No, it goes to this:You can see it exiting the cabinet here Overhead Report
January 13, 20179 yr comment_751975 I particularly like the heatshrink sleeving over the braid. That is really tough to do without melting the braid. Report
