KGSSHV Carbon Build Thread
  • Replies 2.1k
  • Views 660.6k
  • johnwmclean
    johnwmclean
  • johnwmclean
    johnwmclean
    My own Carbon, not going anywhere... IMG_6585 IMG_6590 IMG_6592 IMG_6593 IMG_6595 IMG_6596 IMG_6597
My progress
I ordered a toroid with 360X2 @350mA but I don´t know what I can do. With this trafo, a 400 vol output is a overkill?
I would like use a 20mA configuration on amp.
Nice work Jose.
IIRC, the dropout voltage on this regulator is about 9 VDC for my 400 VDC setup. With a 360vac secondaries you should be able to get reliable 450 VDC regulated output without issue accounting for mains fluctuation.
I believe Kerry has a related post on this matter here in this thread.
Edited by mwl168
Thanks mwl168.
I was wrong because I saw the pcb layout and ordered a 360 Volt trafo for 400VDC
Well If I use 450 VDC PSU (All I need is change four resistors on de the PSU and it's easy), Need I change something on amp boards?
just the resistors on the psu
45 minutes ago, jose said:
Thanks mwl168.
I cannot tell for sure from the photos you posted but make sure your pre and post regulation filter caps are up to spec. Looks like they are all 550VDC rated?
I took a quick look at the Carbon amp board and I cannot think of anything you need to change going from 400 VDC rails to 450 VDC. Others might chime in if they spot someting.
By the way, on my setup, I can barely feel a temperature on the PSU heatsinks after hours of running my Carbon with 20mA output setting (I think my trafo has 330 vac secondaries). The amp heatsinks are a different story, they run VERY HOT, much more so than the KGSSHV. That's another thing to keep an eye on.
Edited by mwl168
Thanks. Yes, all caps are 680uF/550VDC.
Well done jose.
I was going to post these images in the builds thread but it’s missing in action.
Thanks to Kevin and Birgir for being awesome.
Thanks to Michael (mw168) for all the work you’ve put in with the group buys and documenting etc it’s been very helpful.
A couple KGSSHV Carbon amps running 400V @ 20ma, GRLV supplies, SUMR transformers.
What a lovely build you have there, and so very compact too. Those offset trimpot adjusters look interestingly positioned.
Another professional-looking-premium build.
State of the art !
Congrats! Those look awesome.
Which one's mine....?    :wub:
Thanks guys!
As to the sound,
I’ve had a fairly good listen now, I can confidently say It’s a good improvement in performance from the KGSSHV’s and BHSE I have on hand. I’ve always maintained the BHSE and KGSSHV were a similar calibre, with different signatures depending on your taste and music genre.
Interestingly I find myself in the same scenario with the Carbon and the T2, I don’t prefer one over the other, both have slight contrasting differences. To be crude and simplistic, the Carbon has transparency and the T2 sweetness and tone, but both amps do everything exceptionally well.
The Carbon is unquestionably the most stable amp in my arsenal, do we need servos on the next board runs?
The highest reading I‘ve had on start up is around 15V and this quickly settles, I will try the servos at some stage to see if how they perform.
Yeah, the servos really aren't needed from my experience as well - it is super stable from the get go and settles very quickly.
