The Menace
  • Replies 500
  • Views 107.3k
  • In addition to a regulator for the PS, a CCS plate load for the first stage will decrease distortion, a CCS cathode load for the second stage will also decrease distortion, and using a MOSFET instead
  • mypasswordis
    mypasswordis
    Hey hey, come on now, the main constraint of this exercise was OTL  give the man what he wants, even if it is worse.
Shouldn't we be calling tkam's The Menace Heavy (or The Heavy Menace)?
Nate should put little name plaques on all the Menaces (a la Hertsens DAC) so it'll be easier for us to tell. :)
My vote is for "Menace Heavy" and "Menace Wee Heavy"
The Official Naming Convention of Menaces (Menacie?)
The original will always be simply "The Menace". (approx 50lbs)
The most recent incarnation is "The MenaceTC Lite". (approx 30lbs)
The forthcoming stupidly expensive 307A-based nonsense is tentatively called "Colossus". Since the topology is so different I decided a while back to give it an entirely different name. I'm not sold on the current one, but until something better comes around it is what it is. Someone could, if so inclined, build a MenaceTC that would bear a strong similarity to the original and would be even heavier but that amp would look significantly different than the 307A amp. I also won't be able to share the schematic I'm using for the 307A amp further separating it from the original Menace concept.
As for what it takes to be called Colossus, well here's the current pile o' parts.
That is one bad-ass pile of parts! :eek:
Sorry to continue the name game, but given the comment highlighted above, I have to suggest
Star_Wars_Episode_I_-_The_Phantom_Menace%2C_by_George_Lucas%2C_1999%2C_Natalie_Portman%2C_Ewan_McGregor%2C_Liam_Neeson.jpg
Just for fun, see if you can fit an 0C3 glowtube on your latest creation. It doesn't need to do anything for the circuit other than give off a nice purple glow to let you know the high voltage supply is working.
^ I was trying to remember that name the other day -- thanks!
EDIT: Also: Leviathan.
Pic didn't show up.
Which is ironic, as "" was the name I thought you were suggesting, which wasn't too far off, ackshully.
(To others -- it was "the Phantom Menace" movie poster.)
Edited by Dusty Chalk
Goliath should be in the name shortlist. Juggernaut and Colossus are also awesome.
Vulcan and Cratos have the suitable mythological overtones too.
I look forward to seeing the completion of this electrical tower of babel.
I find it amusing that most of the names mentioned are also names used for Marvel Universe characters, and the exceptions, Leviathan and Cratos, have been used in video games.
Yes, 2 of them :)
I figured as much, considering the box and that I would imagine you would have more than one channel of output:p
Why not? (Just curious.)
id like to put in a vote for thanatos. or xanatos. both are names for the same god but xanatos just sounds cooler. thanatos seems nicer given what it stands for.
