The analog thread.
  • Replies 2.3k
  • Views 579.5k
  • tom_hankins
    tom_hankins
  • Craig Sawyers
    Craig Sawyers
Finally got around to cleaning some used vinyl. I ended up going with DIY route, and picked up some chemical nonionic surfactant that was recommended on the library of congress page to make a little home brew solution that ended up working really well. Got a $3 painting edge pad from Home Depot for a wet brush, worked perfectly! Rinsed off in sink using normal faucet water, then did a little bath in distilled water set in a basin, dried off with some microfiber towels, and voila! Nice and quiet and clean on some of grandmas old records and my used vinyl digs. Cleaned about 20 records for about $5 at most of materials.
Hmmmm..... edge painting pad...... nice idea. I make my own out of velvet, foam, and wood, which is a pain in the butt.
I found my Decca brush making scuff marks on my records, so now I'm using a similar wood-foam-velvet cleaning brush with a drop of old time Discwasher fluid for pre-play dusting on the turntable.
By the way, allegedly, you can use diapers -or was it maxipads? - for drying. Anything to do with microfiber confuses me, so I just bought the SpinClean towels. Cheap enough.
The edge painting pad works perfectly, it literally tracks along the grooves smoothly and the brush itself caused zero marks and really pulled junk out of the groove well. Ill check out the spin clean cloths too, as the drying would probably be a little more efficient.
While I find the Clearaudio Statement impressive for sure, how can they justify $200.000?
I think the VPI Titan @ $48,000 would seem a bargain in comparison.
Edited by swt61
They're all playing the same stupid game of the ultra high prices which we can find on any other hobbyist specialized market like watches. Clearaudio has been playing it for the last 20 years, I can't recall a single Clearaudio deck that was a great value for money. Even the affordable entry level models were a POS compared to what you could get from Project, Music Hall, Nottingham, VPI, Michel Engineering or even Rega.
Yes, but it takes a $200K table to run a high $$$ cart into the label...
Can i own anything for more then a week without pulling it apart?
No.
No filthy veneer from the Hevea brasiliensis tree allowed in my livingroom!
Hope you enjoy the company of your fellow plastic friend!
you will soon be replaced by this, sweet, sweet walnut.
I once put a Clearaudio cartridge on my turntable. I chose it over another brand as the dealer told me the stylus was replaceable. Sometime later, the stylus broke, and when I went to get a replacement, I was told that in fact the stylus was not replaceable, but that they would give me a $100 trade in on the broken cart. They suggested that a trade in discount was the equivalent of being able to replace the stylus. I suppose it would have been had the discount been a little steeper, but $100 off a $650 cartridge was laughable.
At only $150k a Steinway D is a solid 220lb heavier than the 770lb Clearaudio, much better value. Needs occasional maintenance but should last 30 years before needing to be rebuilt, and gives you way more audio satisfaction
Especially if you have a Westworld robot to play it for you, in the nude.
I guess I brought it up because I love turntables and I love engineering. Combine the two and you really have something. But throwing a bunch of pretty parts together and charging an absorbent amount of money is boring. Dazzle my eyes and my ears!
progress.
the base plinth is veneered and currently drying with the first layer of oil.
will start on the top plate tomorrow.
Nice job, and major kudos for matching the grain in the corners!
Thanks!
Hadn't done any veneering since 2013, so i had to redo all the mistakes i had previously learned to avoid - still turned out pretty good though.
I even infused it with several liters of blood from over enthusiastic knife-handling, just to bring out that subtle reddish hue in the wood...
Yeezh but lollers -- now that's what I call putting yourself in your work.
they might have been milliliters
Seems you might be suffering from blood loss?  Have a cookie or something.
Looks fantastic!
Always wanted to learn to laminate with nice woods (without the blood).
Can't wait to see how it comes out!
A Steinway D won't fit in my condo, but I have a Falcone 7' that sounds pretty nice - this is the Falcone made by Santi Falcone in Haverhill, MA in 1988, not the stencil brand made by Sejung.  Weighs about 900 lb with a 1.5" thick rim.
Edited by JimL
Cool! Did you buy it from him originally? And have you ever tried a Fazioli? I "played" on a Yamaha G2 from age 2 but didn't get very far with it before changing instruments... one of the big regrets I have is not sticking with it.
