Anyone ever re terminate a Cardas Sennheiser cable?
If the wires are enameled you can burn it off with any iron worth anything and it doesn't get any more simple than cutting the end off a cable and soldering on whatever termination desired. I think we can pretty much end this thread with that.
Yeah, that's why you're asking about re-terminating shitty cables and why you think for some reason 5 feet for a headphone cable is long enough.
I wouldn't go so far as to call it shitty. Snake oil maybe.
I think 5 ft is long enough because I sit right next to my gear and listen
I'm curious about that as well, if I consider myself a decent DIYer I'd just as much go and buy the cable and do it than wait around for replies to a post. Probably could have been done with the cable by now, actually.
I always like to see if anyone has done anything similar to what I am thinking about doing, and the 10ft 1/4" cable is out of stock. I saw no harm in asking just to see if it had been done before.
Thanks for the warm response
Ooh, can I give the advice for those questions? If he thinks he's confused now...
real DIYers have solder pots. noob.
Pffft. Real DIYers have MAPP gas torches ...
You're always welcome to share your wisdom with me, loverboy. :P
Aren't you confused enough already? :D
Yep i have one of those. Needed when i changed out my
water heater. Not enough whoopie out of a propane torch
to sucessfully solder the copper fittings. Almost as good
as an oxy/accetyline torch without the required large
cylinders.
Have a small hydrogen torch for some specialty work :D
Super-geeky DIYers hold their soldering iron like a light saber and make whoosh-whoosh noises.
Yours too, Dusty? Thought it was just mine. Something something something Dark Side.
Yep......Have a small hydrogen torch for some specialty work :D
Safe cracking?
Edited by Augsburger
cylinders.
I learned exactly what you're saying when I was finishing my basement 5 years ago, and the damn pipes kept leaking and I couldn't sweat the joints properly with propane because it wasn't hot enough (especially after turning on the water and getting the pipes wet and leaky). Doh!
