Clarification on Blue Hawaii Power Supply
Actually in this case if the unregulated primaries are where they should be (about 440 vdc under load)
then running the outputs at +/-350 actually causes the pass fet to dissipate more power than if it
was running at +/-400. Reason is that most of the power goes into the output tubes which are driven
from a constant current source that will change very little between 350 and 400 volts.
Suggest you measure the unregulated B+ under load to see if you can swap out the zeners for the
higher voltage. Running the power supply unregulated is not really a good thing.
BH and BHSE amplifiers were designed to run on +/-400 volts.
T2 runs on +/-500 volts.
kgsshv can run on 450 volts, or 500 volts.
  • Replies 73
  • Views 23k
I'm not sure I agree. The extra heat will go into the tubes, sure, but that will raise the ambient temperature considerably. Look how the tubes are recessed. Agreed that the pass device takes a bit of abuse as is, but these things seem to run on the brink of instability as getting rid of all that heat is hard. Granted, there is a lot of ventilation, but my experience what happens is that the tubes heat up the MOSFETs and the ambient temperature of the heat sink and things seem to just cook from there.
I was commenting on the heat from the power supply. Clearly the current sources
and the tubes get hotter at higher voltages. The power supply heatsinks are slightly
undersized and might be able to be replaced with the 2.5 inch versions. The current
sources have plenty of heatsink. Most of the tube inside the chassis definitely
raises the inside temperature a bunch.
I'm primarily referring to Augsburger's response above and Grawks plastic chassis response. There have definitely been some helpful posts in the thread, it just went downhill when the seller was brought up.
Augsburger's response was in fact a question and only that. If you felt hostility from a question that quite well was rhetorical in nature then perhaps you need to rethink what you are doing..... or maybe not. Hmmmm.
Edited by Augsburger
Ok- this is annoying me. Kevin and I exchanged a few PMs and he had mentioned the 'trevornetwork' thing, and that I should do some searching on HF. I decided to do so, and I think the only thing he and I have in common is our name. We don't even live in the same country!
Yes, I suppose it would be annoying that people can still figure out who you are.
?! Ok. I am a 35 year old guy who has lived in GA for quite some time and grew up near Buffalo. I mean, sure Buffalo is near Canada and all, but this is pretty insane.
Trevor W.....
Work Experience
ArcSight / Sales Engineer
2007 - Present
Originally Based out of Ottawa, Ontario. Currently in Atlanta, GA.
Fortinet, Inc. / Pre / Post Sales Training
2004 - 2007
Based out of Vancouver, BC and Ottawa, Ontario
Stop playing stupid.
Trevor W.....
Work Experience
2007 - Present
2004 - 2007
Oh what a tangled web we weave, When first we practise to deceive! - Sir Walter Scott. And that's not crap!
Trevor W.....
Work Experience
2007 - Present
2004 - 2007
Nice!
*g* yeah, I did some stupid stuff back in Van. My intentions were good, but it is what it is. Life's changed a great deal in that five years. Shame on me.
why lie through your teeth and claim innocence and annoyance? How about you just slink out of here and also stay off the other place as well, you've burned your bridge.
Edited by jp11801
This little turd is trevornetwork? Holy shit, I feel dirty...... I gave him the FPE files from my Exstata build, because he seemed like a genuinely helpless newbie on Head-Fi :angry: :angry: :angry:
Edited by Beefy
Oh boo-fucking-hoo you deceitful little bastard. As JP said, get the fuck out of here.
This got interesting really quickly.
Anyway, I wish I'd had a chance to buy Naaman's KGBH the first time around, but it was gone before I ever knew it was for sale. At least I got his O2 Mk1...
Edited by HeadphoneAddict
