What Are You Building Today
  • Replies 2k
  • Views 499.8k
That's Volkswagon's clean diesel technology PCB.
On 5/20/2016 at 9:25 PM, JoaMat said:
Did this one today. Layout file name is JimL_CS.LYT.
a step in the opposite direction ...
f9oURcF.jpg?1
4 minutes ago, JoaMat said:
Great!
 T2 current sources with c4686 instead of c3675?
Yep...had it running for a few weeks in a Carbon before blessing it with  some plates ;o)
Ok, got a differential front end (balanced-balanced and balanced-SE) working today and zeroed DC offset on a whole lot more of these little modules. Seems to perform really well!
Picked the wrong time to upgrade Diptrace. The old licenses aren't compatible with the new version so waiting for sales to help me upgrade. I am pretty sure my old license would work on the older version, if anyone was interested in a "slightly used" software license :)
I went through the upgrade recently.  I think it took  couple of days all in.
I like the new version :)
8 hours ago, Dusty Chalk said:
couple of days for a software upgrade?!?!?  I'm reading that wrong, I'm sure I am.
Well, it is called "Diptrace" after all.
The delay is because you need to get approved for the not-for-profit version.  I'm not sure how much faster it is for the regular versions.
So I wanted to replace the foam in my 007 Mk1 headphones.
I modeled them in up (I love having a mill :)) and here's what I got...
Splendid! Nice work indeed.
I’ve a mill, but have to figure out how to make the model…:confused:
Thanks.
You need to get Fusion 360 and learn how to use it B)   It's from Autodesk and is free to individuals and small businesses.  It took me about 3 hours to model these.
Wow
Me want mill.
What type of mill are you using? Is it easy to use? I mean software wise?
