October 14, 20179 yr comment_776376 Interested in this. A HD650 with more sub-bass. https://www.stereo.net.au/news/sennheiser-announces-hd-660-s-headphones Edited October 14, 20179 yr by wink Report
October 14, 20179 yr comment_776377 I'd be more interested in an HD600 with more definition, less distortion and reaching lower frequencies. I don't think such thing as sub-bass even exists. Report
October 14, 20179 yr comment_776380 I may be a basshead, but I'm not a dumb-bass, so I will await reviews and/or measurements. I doubt I'm interested either way, I have neither a HD600 nor a HD650 in my collection. Report
October 14, 20179 yr comment_776393 Maybe Sennheiser decided that they rather produce their own "HD650 on steroid" that many have been wanting. The cable plugs on the headphone side look similar to those on the HD650. It would be nice that the aftermarket cables many have invested on can be also used for the new headphone. Why so many rings on the TRS plug shown? Edited October 14, 20179 yr by mwl168 Report
October 14, 20179 yr comment_776395 32 minutes ago, mwl168 said: Why so many rings on the TRS plug shown? To let more sub-bass through. Report
October 14, 20179 yr comment_776396 From the linked article: Quote ...supplied with detachable cables, with either a 6.35mm stereo plug or balanced 4.4mm Pentaconn stereo plug. The picture appears to be of the 4.4mm pentacon plug. Report
October 14, 20179 yr comment_776398 12 minutes ago, n_maher said: From the linked article: The picture appears to be of the 4.4mm pentacon plug. Ah, that explains it. Thanks! Looks like the 5 contacts arrangement, instead of 4, is to allow it to be used for both single-ended and balanced amps. I wonder what kind of risk it incurs when plugging and unplugging from an energized headphone amp? Report
October 21, 20179 yr comment_776852 That connector is a balanced connector only. It's very compacted and is gaining popularity compared to 3.5 and 2.5 mm balanced jack. I use that Pentaconn connector with my Sony NW-WM1Z and TA-ZH1ES amp. Report
October 21, 20179 yr comment_776855 5 contacts will allow for single ended use as well if the amp can handle it. Report
October 21, 20179 yr comment_776856 Don't understand the rationale of going through the trouble to develop a 5-pin TRS connector when a 5-pin XLR connector would have serve the job better and is readily available. I guess one of the rationale is the pentacon connector can be made to be backward compatible with a typical 3-pin TRS connection. Edited October 21, 20179 yr by mwl168 Report
October 26, 20179 yr comment_777166 Since its 4.4mm and not 3.5mm or 6.35mm, how will it be backwards compatible? Report
October 26, 20179 yr comment_777171 7 hours ago, penmarker said: Since its 4.4mm and not 3.5mm or 6.35mm, how will it be backwards compatible? I missed that it's a 4.4mm so not even backwards compatible. Sigh! Report
October 26, 20179 yr comment_777172 Once everyone adapts 4.4mm, then everyone is backwards compatible, both single ended and balanced. See how that works? See all of the high quality and inexpensive connectors out there? Sent from my iPhone using Tapatalk Report
October 26, 20179 yr comment_777173 Better to use XLR, no issue with shorting outputs when plugging in too. Report
October 26, 20179 yr comment_777174 I don't need this. I like my HD600. I don't need this. I like my HD600. I don't need this. I like my HD600. I don't need this. I like my HD600. I don't need this. I like my HD600. Report
October 26, 20179 yr comment_777197 Digital, high res, DSD with quantum particles and string theory added for better plankton retrieval. Report
November 11, 20179 yr comment_778158 it will go to 11 for sure, but you already knew this, right? Report
November 11, 20179 yr comment_778179 sub-bass is for sub-normals Discerning music listeners just need bass. Report
