Post the last thing you bought!
  • Replies 21.8k
  • Views 2.9m
Wow, three pairs in one day. If you still want a pair of A5's let me know. :)
I may end up getting a pair of A5's at some later date for the office but for now I will just use my Swan M200's there.
As for the Quads, I suppose I will probably want to use these a balanced source instead of the Pico Dac. So I will need to run ~15ft interconnects to them (or completely change my setup which I don't want to do). I assume that this length is fine, right? Also, will there be any problem powering these from a different outlet than the source?
Happy Quad Day!
Chris, don't you know today is Quad day. :)
Now I want a pair too. How often is it Quad day? Weekly, Monthly? :)
Legal advice.
And I didn't particularly like it.
Oh, and I'm the perv! :rolleyes:
Your counsel advised you had no grounds to challenge both the cease and desist, and the restraining order issued by the sheep? ;)
Everyday is Quadday!
We're sure Lanemark has these many units, right? ;)
And I thought it was mandatory to have the A5s to order 12Ls.
You certainly don't have to, I run mine exclusively single ended.
Should be ok for balanced cables, yes.
Hard to tell, I run mine off of an isolated power source now but I didn't have any problems when they shared a power supply with my source. The only real advice is to try it and see how it goes.
Stretch, I don't like the sound of legal advice. :(
BTW, anything unusual about the pin positioning on the Quads XLRs? Need to pick up a cable to use with one of the Parasounds.
It might be a good idea to introduce yourself first. Read your welcome PM, it'll save you lots of grief.
I am told there are two pairs of Quads remaining if anyone is interested.
Do I need a pair of these Mike?
Depends on your use. It's almost a waste if you can't play them at a decent volume, imo. However, for a desktop rig at home, yes you do need them.
Yeah they would probably replace the HK soundsticks hooked up to the Mac Pro. Can you send me the contact info for this guy?
