ecp audio
Cool! Good thing for the new, bigger place! How did you used to that in your old place?
  • Replies 377
  • Views 290.4k
Sweet! I don't need another amp... that's what I'm going to keep telling myself.... at least for now.
Edited by shellylh
The usual simple elegance, Doug. Congrat on rolling them out!
I concur. A nice refreshing change from some of the more "baroque" designs out there.
Obviously, given how much I liked your previous generation of amps I am a fan of this one from an aesthetic point of view.  One thing - what's the story with the Neutrik combo jack?  I can't quite tell but it appears to have the typical 3-pin layout so I'm left confused by its presence.
Sorry for the confusion. It's just a TRS jack -- the 3-pin portion is not connected.
I used it because a) TRS jacks are all ugly, and this was the least ugly to my eye, B) it will fit the same front panel as a 4-pin jack just in case someone were to work on another amplifier that was balanced but which had a similar profile and could fit into a similar case.
Just shy. I had a piece of almost the same size I tried to will into a pair of sides with no luck.
knobs need to be 2 inches or more thick.
reason is I have to have something to grab onto reliably to
put the insert in. once the insert is in, I can bring it down to
about .8 inch deep. machining into the insides of an expensive
2 inch collet chuck might get someone really pissed at me if
I make a mistake.
I have enough now for about 20 ebony knobs. but none
are absolutely black like the few I had made previously.
will be getting enough wood to make doug a pair of panels
anyway.
need to find someone that has been sitting on a piece of
pure black ebony for 30 or 40 years.
The obvious joke is Steve.
slightly less obvious: pretty sure larry at headphile has had the patent on ebony for the past 30-40 years.
