KGSSHV Carbon Build Thread
3 hours ago, joehpj said:
Changed several sands, and resulted in BC557s fried.:( Suspecting .047uf cap leakage because the voltage of 20K kept raising (~15V) and opposite side LT1021 voltage dropping. Will change all the sands and caps. I think this is the fastest way now for me could thought of. Luckily I still have same spare parts.
How do you guys think?
did you check continuity in rgrds to the lt1021 socket like @GeorgeP suggested? or clean up and resolder the joints before replacing sand?
  • Replies 2.1k
  • Views 691.9k
  • johnwmclean
    johnwmclean
    Finally done! I regrettably sold my previous KGSSHV Carbon a while ago, this one’s not going anywhere soon. This is a 400V, 19mA version, using the ground plane amp board, Sumr transformer a
  • My own Carbon, not going anywhere... IMG_6585 IMG_6590 IMG_6592 IMG_6593 IMG_6595 IMG_6596 IMG_6597
I have mine repaired and back up and running. :wub:
Again I am impressed of its sound compared to the conventional kgsshv.
exquisite ... must be the "state of the art" build!
Beautifully done John. What's the "thing" fastened to the back panel between the IEC and XLR sockets?
15 minutes ago, spritzer said:
My voltage selector board.  :)
is that really all you have to say about this build? in all fairness John's build seems like "the best" build Carbon shown on the forum - there has been others fine builds, but not as exquisite as this.
The only problem is that it doesn't have a normal bias socket.....       :P
Yeah, yeah.....   I know.....  John doesn't have a normal bias earspeaker......     but I do.........    :lol:
Very tasteful build John!
That is the most gorgeous slab of amp I've ever seen. There simply are not words...
Wonderful build. What are the red pads under the caps?
John knows full well what I think of that build even if it is none of your business.  Not everybody gets to print my full name on an amp...
I like the pattern on the top plate, reminds me of the pass f5x chassis buy a few years back
Incredible build John!  I'd ask you to adopt me but I'm probably older than you are.
Thanks guys.
Insanity, from habit I always raise the capacitors off the boards, but because they are horizontally challenged as well, the flat rubber rings (from a plumbers supply) help disperse weight without chance of sagging.
nopants, you are right on the money, the top plate design is indeed inspired from my f5x. The front panel also has the bevel on either side which also matches the f5x look.
A great build as usual John. Must start on my Carbon build
Superb. And it has your signature… one could see from far distance that it’s a John William McClean coming, something like Mercedes S Class.
Congratulations John. As usual, always way above the 90th percentile !
