Blue Hawaii Special Edition
Christ. Now I don't know whether to get grey, black, or silver.
Silver would match your NAD:
  • Replies 1.5k
  • Views 424.6k
  • luvdunhill
    luvdunhill
I'd rather hear about the virtues of $10,000 Esoteric CD players.
The Esoteric K-01 which is the source I have, has the three things I look for in audio equipment, Sound quality, Build quality and Looks, but in the UK it's £15,000. Is it worth that amount of money ?, IMO No. Yes it does sound pretty amazing but if I was able to buy it directly from Teac, I bet it would be around £8000 to maybe £9000, but to my knowledge it can't. This is one of the reasons why I've got and I'm getting my headphone amps from Headamp because they're got directly from Justin. If the BHSE was only available the same way the K-01 is, then I'm guessing it would be $10,000 to $11,000 maybe more.
P.S. I paid £10,000 for my K-01, but I used my previous headphone system as part exchange, to which the headphones were SR-007mk1's. It didn't bother me letting those headphones go because the amp I had to drive them was the SRM-007t and I wasn't impressed with that combo. I've since heard someone else's SR-007mk1 with my BHSE and I'm regretting letting the SR-007mk1's go.
Like I said though in my previous post, I think this clueless cunt will just read other's posts rather than write the same useless shit.
STFUA!
funny, I got a blue BHSE because it matches my nads
Great read Tyll.  I agree wholeheartedly with regards to the BHSE.  It would be interesting to throw the Electra in the mix as well whenever it actually comes out.
Edited by Tari
Great review and I felt compelled to write a bit as to why it's important to open the amps up a bit.
Thanks mate, really appreciate the words of someone who knows what's up.
I was kind of easy on the amps.
But I think I got the main ideas across.
And Justin (and Kevin), that BHSE is bad ass. The control over the drivers was a pretty damned obvious after a while.
Hey Tyll,  I am not sure, but I wanted to call to your attention something that I noticed in your video.  You made reference to the T2 and stated that it was designed by KG.  I'm not 100% sure, but I believe that the T2 was reverse-engineered from the Stax SRM-T2 (You probably know better than I).  If so, I wanted to point this out in case it warranted a correction.  Should it be referred to as the T2 DIY?  Maybe it doesn't even matter??  Anyway, now that I've done my part to be "helpful,"  Thanks very much for the review.  I really appreciate your perspective window into the sound of these stat amps.  Thanks again.
It is known as the DIY T2.
And it is reverse-engineered from the SRM-T2 by KG.
There are many improvements to make it better than the original.
@Tyll - two thumbzup on yer review!
Edited by livewire
The T2DIY is indeed 100% a Stax design on the amp side.  Our version is miles better in terms of noise, stability and is actually run at full power (not 50% as Stax did) but the design is 100% theirs.  What's in the PSU box is all Kevin's work.
Thanks Stretch! Your amp is fucking sick.
Woooooot!
Thanks for the pictures. I'd never seen it before. And great article, as usual, Tyll!
Edited by Hopstretch
You're most welcome. I love the way it's aluminum luster glows.
121225_Feature_EstatAmpsForSR009_photo_B
Getting tucked away in its cozy box.  Lemme know when and where to send it when the time comes.
